Holiday Rambler 2005
Capt Paul, if you are talking about the AC drier that goes inline on ACs it should be right around the condenser.
Time to get the VOM out and start tracing back. Sure you have checked fuse and if it's a new compressor I assume it has full charge Freon. Should have a low pressure switch or thermostat just start following wire back from compressor clutch coil. Have you checked to see if 12 volts are at the clutch coil?
capt paul
thanks for the help. found faulty (brand new) compressor. should have checked clutch before installation. understand this is quite common.
Never assume just because the part is new it's ok Capt Paul. Mechanic nightmare bad new parts and you have to replace for nothing if it's a customer.
