I have a 2.8 Onan microlite RV generator when its cool it will start, and run until I shut it off, once I shut it off, it will re-start if done within a few minutes, but wait 15 or more minutes, and it will not start for at least a couple of hours. I have replaced the ignition coil, and the spark plug, since I do not get a constant spark when it fails to start, but, just one spark when the start button is released. I have checked the magneto voltage at the time that I am not getting a constant spark, and it reads 31 volts which is within normal range when cranking. At this time I have run out of ideas, maybe someone out there has had a similar problem and can help me.
Thanks
Al
22
Thanks
Al
22
