1970 Trailblazer
Discussion in 'General RVing' started by msc2375, Dec 19, 2005.
  1. msc2375
    msc2375 New Member
    I recently aquired a 1970 Trailblazer Travel Trailer. I believe that it was made by Komfort, but I am not completely sure. I was hoping for some help in finding any sort of information on this RV, My search on the major search engines came up empty. I'd appreciate it.
  2. voyager20
    voyager20 New Member
    1970 Trailblazer
    Hello msc2375
    By any chance would it be a Komfort Trailblazer currently built by Thor Industries? It looks like they made a TT and a 5th wheel Trailblazer. Thor acquired a Canadian company named General Coach which I think may be the original builder in 1982. (At least all the references I can find using the trailer names etc. refer to Canadian Manufacturers.)
    Good Luck!!!!
  3. voyager20
    1970 Trailblazer
    Hello again,
    It has to be a Komfort (you are correct). I know they started building trailers in 67. Komfort is now owned by Thor. They have a home page with Oregon Phone numbers where you should be able to find some answers about your specific trailer. (forget the General Coach, I was headed down the wrong path...)
    Komfort
    12628 SE Jennifer Clackamas, OR 97015
    Tel: (503) 722-5199
    Fax: (503) 722-5193
    Hope this helps.
  4. s.harrington
    1970 Trailblazer
    You may be able to find an ID tag on the trailer with the manufacturers name on it. Its usually on the lower curb side front corner. Being that it is so old though it may be gone. Also on a lot of the older rigs, they put a data sheet on the inside of a cabinet door.
