1980 COACH Monitor panel works on 120V, but not on 12V.
Discussion in 'Class C Motorhomes' started by MUNCIE, Sep 4, 2009.
  1. MUNCIE
    MUNCIE New Member
    I'm a rookie here, and just picked up a 1980 coachmen Leprechaun. The problem is that the monitor panel works when I have it plugged into the 120V shore line, but it does not work off the 12V battery. The battery is new and fully charged. I removed the front monitor cover to search for a fuse but saw none. I checked the fuses in the van fuse box and the fuses at the power converter and they all seem OK. Any ideas what I'm missing?
    Thanks all in advance
  2. MUNCIE
    MUNCIE New Member
    RE: 1980 COACH Monitor panel works on 120V, but not on 12V.
    I just read an older post that says something along the lines of a rocker switch in the truck cab that may control the 12V power to the house part. I do have an aftermarket rocker switch that may be my answer! I did not know what it did, I figured it was exterior lighting or something, and was not aware that the 12V monitor panel has a switch. I'll give it a shot when I get home from work.
