RE: 1989 Pace Arrow heat problem
There are two ways automotive heaters allow heat into the vehicle, one is with a valve that lets hot water enter the core from the engine, the other is a door that opens to allow the heat to go into the vehicle. In this case the core allways has hot water going to it and the door either lets hot air in or keeps it out or mixes hot and cold. Because you say both pipes are hot my guess is you have the door style and its not opening.These are usally controlled by vacume or somtimes a cable.Trace from were the hot cold switch is to this device and see if the door moves when you move the lever. if its vacume make sure you have no leaks.You will have to take some of youre dash apart to do this.Somitimes it not that easy but i hope this helps.If you have any more questions ill be happy to help.Have a nice thanksgiving.
