1992 bounder
Discussion in 'RV Tips & Tricks' started by tlc4u03, Oct 27, 2007.
  1. tlc4u03
    tlc4u03 New Member
    onan generator 7000 marqis ran out of oil . I filled with oil but will not start just cranking.I Changed the spark plugs and oil filter. Please help any suggestions . :(
  2. Guest
    RE: 1992 bounder
    did u fill the oil filter with oil before u put it on????
    U may have a defective o/p switch ..
    Was it running ok before u ran it out of oil????
    I hope u did not damage the genset....
  3. s.harrington
    Re: 1992 bounder
    Did you run it out or low?? It has a low oil cut off that should have prevented it from getting low enough to damage the engine. Check for spark and fuel. If no spark check points. If no fuel (4.5psi Min.) check fuel pump and filter. Remember that you must have over 1/4 tank of fuel.
