1994 southwind d
How long did you let the front try to come on? Takes mine 5 min sometimes. Mine works through the thermostat. Has zone one and zone two
sounds like a blown fuse,or tripper breaker. I hope that is it, that would be a lot cheaper than a new unit. When was the last time you knew it was running?
prine125
Junior Member
All breakers are good. I think there should be a switch for front, rear or both. Called a transfer switch.
And a few of the older coaches with 30 amp supple had a second power coed for the second air.
