I recently purchased a 1996 dolphin pusher, the generator is up front and there is a heat shield ( i assume) over the generator below the motorhome dash. Mine looks home made--sheet metal, with foam rubber and the a foil heat shield skin closest to the generator. the foil pulled off restricting the air flow to the generator. Does anyone know what the original design was like? I would like to redo this as designed.
Thanks, EWE
Thanks, EWE
