Gabbygoose
Looses cable TV signal strength between the outside cable connection and the Video Control Center. Video Control Center works fine with regular over the air signal and other input sources. TV works fine when connected to the park cable connection directly and over the air. Tried to locate the route the wire takes from the connection in the utility box, looking for a problem area, but loose the route.
Cable line connects via a splitter with the line from the antenna booster then proceeds to the Video Control Center. Therefore running a complete new wire from the utility box to the Video Control Center is not really an option.
Anyone know where the splitter that connects the two lines may be located exactly? Could possibly leave the bad cable in place and run a new line to the splitter if I knew where it was located.
Dave
Dave
