1999 Monaco Dynasty-Turning signal problem
fesfsb33
Good, Evening
I have a 1999 Monaco Dynasty 40' 350 diesel coach. I have developed a problem that I cannot resolve. In daytime driving my turning signals work correctly. When I turn on my headlights, my left signal will not work. Any suggestions. Thanks for your help.
Re: 1999 Monaco Dynasty-Turning signal problem
I was just reading of a like problem on another sight and the resolve was the, I think it's called the horn ring. It's a switching device just under the horn button in the center of the steering wheel. Has to do with the signals.
G
Guest
Guest
sounds to me u might have a dimmer switch prob ,, is u'r high low beam on the column??? if so ,, the headlights and turn sigs feed thru this ,, even the low beams ,, let us know back :approve: :)
i would ck the ground or it might just be a bad bulb that has the filment broke and shorted across the turn signal.
