I have lost 120 power within the large slide out which includes two lights and one electrical outlet. I did check the voltage in this one electrical outlet and only had 12 volts. I have checked circuit breakers and the one gfi outlet all appear to be good. The 12 volt lights within the slide out do work Because I don't have a wiring diagram I have to assume the the 120 power within the slide out is on the same circuit as the TV and entertainment center outlets which do work. If anyone has any ideas or suggestions as to why I don't have 120 power in the slide out I would appreciate hearing them.
Thank you,
Gpa
Thank you,
Gpa
