2004 Alfa Sun...12 volt fuses
Discussion in 'Towables' started by Wynelocked, Sep 19, 2014.
  1. Wynelocked
    Wynelocked Junior Member
    Been looking for the fuse location for this BEAST.Says it's in the front wardrobe...
    NO IT'S NOT!...done everything but dismantle the closet.
    Problem is the outside lites...the ones on the sides,those 10" circles.
    Bulbs burned out twice...replaced them.Both sides.Also the one under the front bedroom outside.They worked for maybe a week or so...then all three went out.Put in new bulbs...none worked.I figure it's a fuse.The book says those fuses are inside the front wardrobe....nope.
    Anyone had this problem before?
  2. Wynelocked
    BTW....good being here.Got alot of reading to catch up on.
  3. LEN
    LEN Senior Member
    No help here except maybe a tone and probe to follow the wiring. Is there no 12 volt fuse panel?
  4. akjimny
    akjimny Senior Member
    My 12 volt fuse panel is built into my voltage convertor. There is a drop-down panel that hides the 12 volt fuses and the 120 volt circuit breakers. With any luck, your will be in the same place.
  5. Wynelocked
    Thanks...I'll look there tomorrow.
