2006 Roadtrek 210 Versatile
zalinalayton
Has anyone heard of a LIFT KIT for a Roadtrek 210 Versatile and where we may purchase one? Our B Van is quite low and a couple of times we've scraped the bottom going in and out of parking lots.
We would like to install one if it's available
Many thanks
Re: 2006 Roadtrek 210 Versatile
Check at one of the off road truck part places Zalina. They should have lift kits that might work.
Pancanbob
RE: 2006 Roadtrek 210 Versatile
Hi, Zalinalayton
You may want to see if you are “overloaded” :eek: :eek:
With smaller RV it is very easy to do. :( :(
Air shocks all around might be the cheapest way out. With an on board compressor installed(you can air tires to)you can raise and lower at will. That way on the freeway you can be low for go and if you add weight or go on that rocky road or in and out of those high and low gutters you can get the xtra clearance you need.
