2007 Newmar Dutchstar 4023 diesel pusher/ electrical issue
Bon Bon
Junior Member
Driving down the highway in the rain an lose all power to the motorhome. Tow into shop to repair. The next morning at the shop there seems to be no more problems. Anyone else ever had this issue?
Check grounds from batteries to frame and the positive connections on the batteries. These type of problem can be the chits to find. I had a cruise control problem and a good tech finally found the problem, a loose connection in the relay panel, the relay was good but the plugin connection was bad. If you think it was a water related issue it will be really hard to find and it may never happen again. All you can do is look around and check connections anywhere on the coach.
