2008 hurricane
Discussion in 'Class A / Diesel Pushers' started by LURCH, May 16, 2008.
  1. LURCH
    LURCH New Member
    I have a 2008 hurricane, V10 when should I be taking it out of overdrive? Only when towing?
    I tow a 14' trailer with atv's about 2500#
    Or should I leave it off all the time while towing?
  2. TexasClodhopper
    Re: 2008 hurricane
    If you're V10 is like mine, then it's peak torque occurs about 2300 RPM (60 MPH in OD). Down around 2000 RPM mine will shift out of overdrive by itself.
    If you can maintain that 2300 RPM in overdrive, then I don't see a reason to shift out of it. You just don't want to be lugging down the engine, but that's not going to happen until about 2000 RPM.
    You have to pay pretty close attention to this while you're driving.
  3. DL Rupper
    Re: 2008 hurricane
    When in overdrive, if it constantly shifts up and down looking for the right gear, put it in tow/haul mode (lower gear).
