30 amp box to 50 amp coach
Discussion in 'Suggestions/Comments' started by lows62, Jul 4, 2010.
  1. lows62
    lows62 New Member
    Our RV camp only has a 30 amp box and my RV is a 50, everytime I run both a/c's it keeps popping, can anyone help me with this? if so, can you make it in clear english :)
  2. Triple E
    Triple E Senior Member
    Re: 30 amp box to 50 amp coach
    Hello Lorraine and welcome to the forum. :cool: Your breaker panel has two hot wire feeding it. L1 and L2. If both of your A/C are connected to L1 or to L2 this could be your problem. On my RV I have one A/C on L1 and the other A/C on L2 and I have no problem running both A/C's.
    Also your problem may just be that both A/C's are just pulling to much current and will not run on 30 amps. Is there a way you can get your hands on a current meter and see just what kind of amps your A/C are pulling? Good luck and let us know what you find out. :)
  3. TexasClodhopper
    Here's the real clear English ... don't operate a 50 amp RV on a 30 amp circuit.
