30 ft sierra battery wont work
Discussion in 'Beginning RVing' started by troy, Aug 12, 2006.
  1. troy
    troy New Member
    i bout a sierra fifthwheel and when i hook up to power everything works fine. it has a charger built in and you can hear it running. but when i unpug the power and try to use the battery nothing comes on. except there is a radio in the camper and it works. there is only one battery in the front. and it is a car battery. New to the fifthwheel and lost. thanks troy
  2. Bush70
    Bush70 New Member
    Re: 30 ft sierra battery wont work
    Make sure your battery disconect is on if you have one. Make sure the battery is good. One thing I had happen a few years ago. The battery charger converter, it has to switch back to 12v. There is a switch in there and the older ones stick. If you tap the converter and it starts working that is it. You can replace that old style switch with a new one that is solid state and it won't happen again.
    Good luck
  3. troy
    troy New Member
    bush70 thank you very much. tapped ounce and the battery kicked in.
    thanks troy
