32QBBS Wildcat
Discussion in 'Talkback' started by chrissyandpaul, Jul 26, 2009.
  1. chrissyandpaul
    chrissyandpaul New Member
    Hi,We are new zealand kiwis and have a seepage of water from under the shower.
    It is constant and I have traced it to the connection of the water pipes behind the shower taps.
    The problem now is ...how can I access the pipes?I cannot get the shower away from the wall.
    Can someone help with advice on how to access the water pipe connections at rear of shower taps please so that I can re-seal or tighten connections to stop leaking down to floor area below shower box?
    Thanks,Paul.
  2. C Nash
    Re: 32QBBS Wildcat
    Welcome to the forum Paul. Most rvs will have a small panel on the wall behind where the faucets are that you can get to the connections. If it's a pipe underneath leaking you will probably have to remove the shower stall
  3. chrissyandpaul
    Re: 32QBBS Wildcat
    Hi,thanks for that.
    THere is a panel behind faucets that was adhesived to wall and I have released that from wall. I cannot get the taps off or get to pipes still.
    Paul
