454 Chevy Engine Tapping
Discussion in 'General RVing' started by JimE, Feb 4, 2005.
  1. JimE
    JimE Senior Member
    I have a 1993 Winnebago Brave with a 454 Chevy Engine. After a 4,000 mile trip this past summer in the heat it developed a slightly tapping lifter. I am getting ready to change the oil, and a friend recommend using Lucas Engine Oil Stabilizer to help. Any other recommendations out there?
  2. st687
    st687 New Member
    I had a Ford F150 with a lot of miles,I bought a can of motor flush at pep boys ,followed directions, changed oil and fiter, ran it 500 miles changed oil and filter again and added the Lucas to it and has been fine ever since. :cool:
  3. C Nash
    Jim, you need to remove the valve cover and check the valve lash if it taps all the time.
  4. Poppa
    Poppa Member
    I agree with Chelse, sounds like a rocker arm backed off. Also there is some thing called engine restore that helps the older engines out
