5th Wheel - Dead Battery
Discussion in 'Towables' started by cavain0914, Mar 10, 2008.
  1. cavain0914
    cavain0914 New Member
    I came home this evening to find that the battery to the 5th wheel is dead. I am connected to shore power, I have power in the electrical outlets but no overhead lighting, heater, a/c or refrigerator. I changed the battery, all worked well until the new battery died. Any ideas?
  2. dennis1949
    dennis1949 Senior Member
    Re: 5th Wheel - Dead Battery
    Have you checked the convertor to see if it is putting out 13 volts to keep the battery charged. If it is start pulling 12 volt fuses one at a time to see what is draining the battery
  3. DL Rupper
    Hey cavain0914, welcome to the forum. Check the convertor fuse if it has one.
  4. tvman44
    tvman44 Junior Member
    RE: 5th Wheel - Dead Battery
    Your converter is apparently not working.
  5. hertig
    also check the water in the battery. If it went dry, the battery is probably toast.
  6. McDonalds
    McDonalds New Member
    I have had the same problem when my connections to the battery from the junction box were loose.
  7. cjones
    cjones New Member
    Can the dealer check the converter to see if it is working.
    We bought a new travel trailer last year and hadn't used it, but when we got the hook up to the house, just recently, the battery was dead and something keeps popping in the converter box. I can get the first two breakers on, but no power and when we try the third and final breaker it trips and there's a flash in the converter.
    Any ideas?
    But when I charged the battery and used it solely we had power to everything
