84 Pace Arrow with fuel starting problems.
Discussion in 'Talkback' started by ramosjac, Jun 29, 2004.
  1. ramosjac
    ramosjac New Member
    The engine turns over fine, but won't start after sitting for long periods. I hear the electric fuel pump whaling away; however it takes too long to prime the fuel line and carb. I suspect that the carb fuel might be bleeding into the engine and the electric pump doesn't have enough volume or pressure to get things going. It starts fine once I spray ether (quick start) into the carb and subsequent starts work until the RV sits for a while. I've replaced the mech fuel pump, electric pump, and all filters. Has anybody experience or seen this condition?
    Chevy 454
    GMC P30 Chassis
    Thanks,
    Jack
  2. ARCHER
    ARCHER Senior Member
    Did you replace the in-line gas filter, also? One in Carb and one in-line, I think. I have Winn Chevy 454 engine and the in-line was nearly plugged. Engine was starved for gas.
  3. ramosjac
    ramosjac New Member
    Thanks for your reply Archer. I have three filters (carb, in-line, and one close to the gas tank)and each was replaced.
    Jack
