95 37 ' pace arrow Holding tank heaters?
Discussion in 'Class A / Diesel Pushers' started by thundercats, Jan 8, 2010.
  1. thundercats
    thundercats New Member
    I have a 95 37' Pace Arrow Motorhome and i am wondering if i have holding tank heaters. I looked under the coach and the gray and black tanks are inside the frame rails with insulation and sheetmetal surrounding them. The water tank is inside the basement storage under the coach. Any help would be appreciated. Thank you
  2. C Nash
    Re: 95 37 ' pace arrow Holding tank heaters?
    If you have them there should be a switch inside the mh that turns them on. probably just heats from the rv furnace but that's a guess Welcome to the forum
  3. Guest
    yes nash is right on all the above ,, i would think that the water tank has a duct from the furnace to it ,, that way keeps all warm ,, but not really sure on the holding tanks , some of the newer models have them wired into the furnace stat ,, that way when furnace is on the tank heaters are on , but that is only in the high end MH's ,, not really sure if a 95 had them or not ?? My bus didn't have them ,, and it was a 97 ,, and also welcome to the forums :approve:
