Re: '97 Bounder winterizing
Today is your lucky day Woodsie ! I also own a 97 Bounder. In the compartment where your water pump is located, look inside to the left. There is where my hot water bypass valve is located. It should be positioned up and down pointing at 12 o'clock and 6 o'clock. "Hopefully" yours is just like mine and that will solve your problem. ALSO, don't forget to close the "low point" drains, and those are "real little" gate valves, mine being located in the same compartment behind the water pump.
I hope I have helped you out, if not let me know as I have all the factory manuals for that unit and also all the maintenance manuals for both the coach and the workhorse chassis. I am not mechanic but will be glad to look up any info you may need.
BB
Sorry didn't read your second post. BUT still willing to try and help you out. I would also check to see that the bypass valve is indeed connected. Sounds like maybe someone may have taken that out of line. ???????
