A/C in Tow Vehicle
I recently bought a 21-foot travel trailer that I tow with a 1998 Chevy S-10. The trailer weighs 3300 lbs and my towing capacity is 5000 lbs. After about an hour of towing, the air condiitoning in the Chevy stops working. When not towing, the A/C works great. Any suggestions or similar experiences?
A/C in Tow Vehicle
Welcome to the RVUSA forum :approve:
The only thing I can think of is cooling temperture. Do you have a temp guage? Air flow through the condenser could be restricted causing high pressure while towing. Towing really should have no effect on the S10 ac. Does it stop blowing? Is the compressor still engaged? Some have a switch to cut off under heavy acceleration. Do you have the 4.3 engine?
A/C in Tow Vehicle
You need to hook up a set of ac guages and see what the readings are when it quits cooling. The only thing that comes to mind is high pressure created by to much heat. Check the clutch fan to see if it is working properly. Does it quit cooling completly? Put a therometer in the ac outlet to see what the temp is. Kind of an odd problem. Has this happened often?
A/C in Tow Vehicle
Haven't looked up any specs on the S-10 but, 5000lbs seems to be a little more than the S10 would handle but think it should handle the 3500. Its possible that the computer is sensing heavy throttle while towing and cutting the ac off but it should cool going down hill if this were the case.
