abs fittings
Discussion in 'RV Tips & Tricks' started by stevencina, Mar 3, 2011.
  1. stevencina
    stevencina New Member
    I am working on the waste pipe and would like to know if you can connect PVC (white) to ABS (black) if not are there fittings available in abs? Such as 1- 1/2" or 2" Thank You....
  2. Guest
    RE: abs fittings
    can i ask u one thing ,, did u have a leak ,, or did u break a pipe ??? ,, IMO i would go back with the black ,,
  3. Grandview Trailer Sa
    Re: abs fittings
    Black is sometimes hard to find, but your not supposed to mix the colors..
  4. RV Trax
    RV Trax New Member
    RE: abs fittings
    Use the Black ABS pipe, because it provides better flexing than the brittle PVC, so it is better suited to withstand the flexing and vibrations encountered while travelling.
