Okguys I got an other problem. Went out and started the genset to let it run for awhile no problem there. However when I turned on the front AC only the red light came on. I know that it will do this for a while until it find the power, but the compressor never came on. Now the rear AC worked fine. So I hooked up the shore power and front AC worked fine. Al though I think it may be low on freon as it not cooling down fast like it use to. So what is going on here. I have an appointment to put in the shop this coming Tuesday to check the short that keep killing the engine battery, so IguessI willlet them look at the AC ,s also unless I find a fix here:laugh: :laugh:
