I am considering purchasing an older RV with a CAT 3116 engine and a Allison MT643 transmission. It does not have an engine or exhaust break. Can this be added to my unit as an add on?
Yes it can. It's not cheap. You also have to wire in a switch in the lockup signal pressure tap on the transmission so an engine brake or exhaust brake is only active when the lockup clutch is on.
