allison shifting erraticlly
Discussion in 'Class A / Diesel Pushers' started by monacosteve, Oct 31, 2006.
  1. monacosteve
    monacosteve New Member
    i currently own a monaco diplomat in the UK when i drive up steep grades the shifting goes up and down eraticlly especialy when i am in cruise it is not so bad when i take it out of cruise,
  2. Bush70
    Bush70 New Member
    Re: allison shifting erraticlly
    What year, engine and trans?
  3. monacosteve
    cummins 277 isb with allison md3060 6 speed
  4. Bush70
    Bush70 New Member
    What year?
  5. C Nash
    Think this would be normal with the combination you have. I would not or don't like to use cruise in steep hilly conditions.
  6. dbarton291
    dbarton291 Senior Member
    I agree with C. Nash. An RV is not a car. You can't put them in cruise and get the same behavior. The powertrain and weight of these vehicles is more like a truck in that they are limited in their performance as compared to a car. As an RV climbs a hill, it will slow down. When it hits a downshift point, the trans will downshift. You then make more torque and speed up. The transmission upshifts, etc. etc.
  7. RUGER9MM
    RUGER9MM New Member
    RE: allison shifting erraticlly
    THE GUYS ARE RIGHT, DON'T USE CRUISE ON STEEP HILLS. YOU SHOULD HAVE A MODE BUTTON ON YOUR PANEL ALSO. IF IT'S ACTIVATED IN THE TRANS. YOU CAN PUSH IT DOWN TO PUT IT INTO ECON. MODE AND THAT CHANGES THE SHIFT SO IT PULLS DOWN TO MAX ENGINE TORQUE BEFORE IT SHIFTS. THE LIGHT ON THE PANEL COMES ON WHEN IT IS ACTIVATED AND YOU CAN CHANGE IT AT ANY TIME IN ANY GEAR. WHEN YOU SHUT THE COACH DOWN AND RESTART, IT WILL DEFAULT BACK TO THE STANDARD MODE. THIS WORKS GOOD ON ROLLING HILLS ALSO, SO THE TRANS IS NOT DOWNSHIFTING ALL THE TIME.. GOOD LUCK...
