Allison Temp Indicator Inop
Discussion in 'Class A / Diesel Pushers' started by swtiming, Mar 24, 2009.
  1. swtiming
    swtiming New Member
    I have a 2005 Allegro Bus with a Cummins 400HP and Allison 3000 transmission on a Freightliner Chassis. Just recently the dash transmission temperature indicator ceased operating even though I have taken it through the mountains on long trips under conditions the needle should be moving but it is not.
    Question 1 is does this gauge have a fuse controlling the circuit? If so where would it be located and what would the fuse be labled as?
    Question 2 I understand the temperature is sensed by a remote (not internal to the transmission) unit where is it located?
  2. dbarton291
    dbarton291 Senior Member
    RE: Allison Temp Indicator Inop
    I am not familiar enough with each OEM to say where fuses are in each one. I do know the sending unit for the temperature gauge is normally located near the transmission, in the hydraulic line that goes from the transmission to the transmission cooler.
