Allison transmission w/ WTEC III control
Discussion in 'Class A / Diesel Pushers' started by bounder bob, Oct 20, 2011.
  1. bounder bob
    bounder bob Junior Member
    Have a problem..on my push button gear selector, nothing works. No lights, doesn't shift and because of this the RV won't start. Any suggestions?
  2. LEN
    LEN Senior Member
    Check the hot wire from the ignition switch. and the cable plugins on the control unit.
  3. bounder bob
    Thanks Len. Checked that and it looks OK. It does briefly flash the display, but goes off before the key is turned all the way...Confused
  4. LEN
    LEN Senior Member
    Does the hot lead remain hot? If it doesn't the switch is the problem. Did you reseat the cabling to the WTEC III?
