Alum Roof Paint
Discussion in 'General RVing' started by ARCHER, Apr 23, 2006.
  1. ARCHER
    ARCHER Senior Member
    So, is it ok to paint an alum roof on a Class A, (Winn, Chieftain, 1989) to help seal up any pin holes that might have developed? If so, is there a special type of Alum Paint to use on an RV roof or can you just buy the silver alum paint from like a paint store or Lowe's or ??? What is the process for applying it? Anything special to do or look for?
  2. s.harrington
    Alum Roof Paint
    The best I have found is the Dyco 890. Its about $40 a gallon but works real well. You should be able to get it at your RV store or if you have one a mobilehome parts house probably sells it cheaper. We have Everett Superior Supply up here. I will post there web site here tomorrow.
  3. s.harrington
    Alum Roof Paint
  4. Kirk
    Alum Roof Paint
    We have friends who used Kool Seal and were very happy with the result. I think that it costs about the same as what was also mentioned.
  5. Kirk
    Alum Roof Paint
    Oops!
  6. s.harrington
  7. Bob_Rabbit
    Bob_Rabbit New Member
    Alum Roof Paint
    I used Kool Seal, worked very well, it went on thin so I put 2 coats on it. Looks good and keeps the inside alot cooler
  8. ARCHER
    Alum Roof Paint
    Thanks all. Can you buy Kool Seal at local lumber yard (Lowe's, Home Depot, etc.)??
  9. Bob_Rabbit
    Alum Roof Paint
    I think I got mine from Wal-Mart
