Another towing Question??? Someone PLEASE help!!
Discussion in 'Beginning RVing' started by maineiac33, Mar 11, 2008.
  1. maineiac33
    maineiac33 New Member
    At all costs I wanted to avoid having to ask another towing question, but after reading WAY TOO many posts this evening I am now more confused than ever. I currently own a 06 Dodge Durango with :
    3.55 Axle Ratio Axle Ratio You Can Tow 5750 lbs
    Gross Vehicle Weight Rating (GVWR) = 6700 lbs
    Payload = 1604 lbs
    Curb Weight = 5096 lbs
    Curb Weight Front/Rear = 2744 lbs/2744 lbs
    GAWR Front/Rear = 3600 lbs/3900 lbs
    Gross Combination Weight Rating (GCWR) = 11000 lbs
    I am considering purchasing a Shamrock 21RS travel trailer for my family and its stats are:
    Hitch Weight 451 lbs. (205 kg)
    Axle Weight 3,032 lbs. (1375 kg)
    Unit Dry Weight 3,483 lbs. (1580 kg)
    GVWR 4,851 lbs. (2200 kg)
    I seem to think that I will be fine towing this trailer, but I suddenly got a little paranoid that I may be way off base. Could someone help a newbee out??? Thanks
  2. TexasClodhopper
    Re: Another towing Question??? Someone PLEASE help!!
    Welcome to the forum, Andrew! (And I just have to say, "Oh no, another Dodge man!" :eek: :laugh: )
  3. H2H1
    Just hold on Andrew, DL the forum Dodge man will get you the right answer. Although I bet it's not a diesel, he will tell you how sweet the diesel smells. anyway there is a lot OF poking fun at each other on the forum, but soon or later you will get YOUR answer. BTW welcome . and what ever you do HAPPY CAMPING.
  4. DL Rupper
    Looks to me that you would be slightly over the Gross Combined Weight Rating by 551 lbs if you loaded both truck and trailer to maximum capacity.
    Truck GCWR 11000 lbs Truck GVWR 6700 lbs + TT GVWR 4851 lbs = 11551 lbs
    I think you could probably get by if you don't load your truck or trailer to capacity. The best thing to do if you buy the Shamrock is to load it and your truck for a typical trip and take it to a truck stop and have it weighed.
    Keep in mind you need to put all the gear, passengers, and fuel in your truck as well as fill the water tank and propane bottles, all groceries, pots and pans etc. in the trailer. if you don't need to take fresh water with you, you can save some weight. . Water weighs approximately 7 lbs/gal. Hope this helps.
  5. maineiac33
    Thanks for the help! I was counting on doing a few upgrades to up the horsepower by about 20hp or so. Would that help enough? My wife loves this trailer, but we are in the process of getting the durango ready to tow. And by the time it is fully ready, she is worried that someone else will have bought the trailer. I just want to make sure I don't push the durango too hard....I need to last!(And no side comments from you Ford and Chevy people :laugh: )
  6. TexasClodhopper
    It isn't really all about horseypower. You have to consider stopping that bad boy, too.
    Don't you watch those Toyota commercials? ;)
  7. elkhartjim
    elkhartjim Senior Member
    Hey Tex...speaking of the Toyota commercial, they lost 6 trucks and One driver (when his parachute didn't open) filming that commercial. They finally used phoney props and a dummy driver. Of course the whole problem started when they were using a Toyota built in USA...they finally had one shipped from Japan. Can of worms just been opened?
  8. DL Rupper
    hey maineiac33, Your rear axel is more of a limiter than your horsepower. A 3.55 rear end is fairly high geared. You would do better with a 4.10 gear ratio, if they make one for your Durango.
