Attwood Gas/Electric Hot Water tank
Discussion in 'Class A / Diesel Pushers' started by chief4-1, May 25, 2011.
  1. chief4-1
    chief4-1 New Member
    Water heater works on either gas or electric. Problem is hot water only lasts for less than one minute.
    Anyone have any thoughts?
  2. C Nash
    Re: Attwood Gas/Electric Hot Water tank
    Need more info Michael. Is the burner staying on when on gas? What about your switch over valve for winterizing? Is it in the right position? I have a 10 gallon hot water heater and we never run out of hot water.
  3. Grandview Trailer Sa
    Your bypass valve is open. You need to close the bypass valve and force water thru the water tank.
  4. chief4-1
    chief4-1 New Member
    RE: Attwood Gas/Electric Hot Water tank
    Thanks for the replies. The gas stays lit and the valve is in the correct position.
  5. chief4-1
    chief4-1 New Member
    Been in this motorhome for six years now. This is the first time Iran into this problem.
  6. Guest
    when was the last time u flushed the water heater?? just a guess ,, u might have enough sediment in the tank that u can't get the full hot water out of it ,, but i kinda have to agree with Ken ,, how many valves do u have on the water heater to bypass for winterizing ,, on mine i have 2 ,, most have 3 ,, but JMO
  7. airspeed
    airspeed New Member
  8. Grandview Trailer Sa
    I am going to say again, the bypass valve is open. You probably have 3 valves and probably all 3 are open. The cross over or bypass needs to be closed to force water thru the tank.
    I get dozens of calls each year about the same thing.
  9. chief4-1
    chief4-1 New Member
    Found the problem. So simple, never gave it a thought. There are two thermostats located on the front side of the water heater. They are about the size of a quarter. They come in pairs. Info came from the technical service guys at Atwood. Thanks to all who offered their help.
  10. C Nash
    Thanks for coming back and letting us know the problem Chief. I should have thought of that. Mine has two also but about the size of a dime. One has a reset button on it.
  11. Grandview Trailer Sa
    Glad you figured it out and are up and running, but I gotta ask, your first post said: "Problem is hot water only lasts for less than one minute." Since it was a thermostat, how did you have any hot water at all? I never thought of them, since it sounded like you had hot water.....Just wondering....
  12. C Nash
    Probably hot water where the hose lay in the sun. :laugh: I know when the sensor or whatever it is went out on mine I had no electric heat water but gas heated fine.
