Bypassing 12 volt converter
Discussion in 'Beginning RVing' started by sbiagini, Mar 7, 2009.
  1. sbiagini
    sbiagini New Member
    Does anyone know how to bypass the 12 volt electrical converter and run the RV on a 110 volt circuit. A family member has her 5th wheel parked on our property and is living in it. Our electric bill has skyrocketed which we think is due to the 12 volt converter. Would appreciate any feedback, Thanks.
  2. Grandview Trailer Sa
    Re: Bypassing 12 volt converter
    Hello and welcome,
    I would be interested in seeing what others say, but I don't think you can do what you want very easily. You see, MOST things in your RV run off of 12 volts. Lights, Refer, Furnace, Water Heater and most other appliances use 12 volts to operate. The only things that run ONLY on 120 are the AC, Microwave and Wall outlets.
    The converter/charger keeps your battery charged to do these things. NOW, if you don't have a battery or have a bad one, that would make the charger run all the time and that would run your electric usage up. I would start your search with the battery and make sure it is good. If you don't have one, install one.
    Your converter needs to be checked also. It should put about 13 volts to the battery at full charge and taper off as the battery charges.
  3. TexasClodhopper
    Sandy, as Ken said, the 12v DC is very important to the whole RV.
    If you don't have an adequate supply of electricity at the RV, then the A/C will use a lot of extra electricity (and it could even go bad.) You have to have at least a 30 amp supply right near the RV. Any extension cords that you use will drop the voltage along the length of the cord so the actual voltage at the A/C might be really low.
    However, since most of the country is in winter weather, I can't see how the A/C would be causing the extra load.
    Also, I don't see how the 12v DC converter or any 12v loads could make a visible difference in your electric bill.
    What you are probably seeing is an extra load from heating strips in the heating system or furnace.
  4. Pancanbob
    Pancanbob Senior Member
    RE: Bypassing 12 volt converter
    Hi, Sandy :laugh:
    Welcome to the Forum :) :) :)
    I don’t know your system’s set up, but the should be a circuit breaker supplying 110 volts the converter/charger. If you open it everything that’s run on 12 Volts stop working. :eek: :eek: :eek:
    I have seen on E-Bay 110Volt electrical meters, for less then $20.00, that will tell you how much power they are using, have them pay for what they use. :dead: :dead: :dead:
    Take care
    :clown: :laugh: :cool: :) :shy:
  5. LEN
    LEN Senior Member
    I guess the question is "What does sky rocket mean in $$$$?" I'll throw out a # and see what others have to say. In moderate weather an RV will use $100 a month in Elect or less in high heating or cooling tome that could double or more. If the relative is using Electric heaters in cold weather and the Electric water heat it could add up in a hurry.
  6. Guest
    I agree with Len ,,, sounds like more than just the normal everyday camping ,, as said ,,, YOU NEED the converter ,,, and also Tex ,, and Len ,,, said what i agree with ,, ,, heat strips in the a/c units ,, (for heat) ,, and possible electric water heater ,,, but as Len said ,,, and rv will suck up some kilowats for sure ,,,, well when one is using it ,,, but JMO ,, as the other's have :approve: :approve: :) :)
  7. sbiagini
    sbiagini New Member
    Our monthly electric bill went from $50-60 to $250-270, to us a significant jump especially since we live in southern California where the winter is mild.
  8. Guest
    well ,, i think IMO ,, u should see what is being used in the rv ,, and maybe cut down from there ,, but i must say ,,, my electric bill last month was 498.00 ,, and that is just for the house ,, but really ,,, ck and see what is being used ,, as said before ,, sounds like alot of full electric stuff being used ,, but one other thing ,, is the rv plugged into a full 30 amp or 50 amp circuit ,, as stated before ,, this will make or break the electric bill ,,, it depends on what is running the rv ,,, like being pluged into a 20 amp small cord and running the rv ,,, hope this is not the case ,,, but just trying to help :approve: :)
    Btw ,, welcome to the forums :approve: :approve:
  9. USMC
    USMC Member
    One can pick up a small solar battery charger for around $30-35.00 which will help keep that battery charged and save the converter from running all the time, also if you are running a 12-2 over 50-75 feet to your RV that is way to far, you might consider running a 10-8 to carry the load which would be better.
    It would probably be best overall if she is going to be there long term to run a 50 AMP service to the RV on a 10-8 wire and in the long run you would save money doing this, actually with the extra bill you have had so far it would have already paid for it's self.
  10. brodavid
    brodavid Senior Member
    Rod, you need to come to the beach, 82 today and Sunny
    love you too,
    msjackie
  11. Guest
    well we were 80 here today ,, and calling for 82 tomm,,, but i am heading to the beach ,, in May as usal ,, but i wish sooner :angry: :angry: :approve: :laugh: :laugh:
  12. brodavid
    730, Dave said you could wash and wax his wheelchair if you want while you are down
    also agrees with the advice that was given
    ms jackie
  13. Guest
    well i don't know about that ,, that buggy dave has will be a real challenge ,, may take me 3 weeks to wash and wax it ,,, but now if he drives it close to the beach ,, well it may never even get washed let alone waxed :eek: ;) :laugh: :laugh: :laugh:
    Take care both of u ,,, :) :)
