check valves in forest river cedar creek 5th wheel
Discussion in 'RV Tips & Tricks' started by bbnaz2, Jul 5, 2006.
  1. bbnaz2
    bbnaz2 New Member
    I have a problem with my kitchen sink. I over filled the grey tank and the water backed up into the kitchen sink. I drained the tank and now the sink will not empty. I'm reading that there is probable a 'in line check valve'. But I can not seem to located it. Under the coach is a huge skid plate, and the pipe from the sink goes below the floor. The storage compartment is accessable, and I see the pipe, but no where can I see where this valve could be easily changed out. I've read that it should be easy to access the valve. I can't find any kind of diagram telling me where the valve is or how to access it. Anyone have any ideas?? Thanks
  2. Grandview Trailer Sa
    Re: check valves in forest river cedar creek 5th wheel
    It should be located behind the sink just under the counter top. If you can see you drain pipes, it will be a fitting leading to it.
