chevy 454 fuel problems
Discussion in 'RV Tips & Tricks' started by paulc, May 24, 2005.
  1. paulc
    paulc New Member
    We have a Trek with a 454 fuel injected engine that quits after being hot under load. It has an in tank fuel pump whitch we think is too weak to overcome a vapor lock. Has anybody cured the problem with an inline pump? If so, what pump did you use?
  2. C Nash
    Guess you have already changed the fuel filter?
  3. Poppa
    Poppa Member
    Several had a similar problem and it was due to a couple things, fel filter and the location of the fuel lines next to a heat source such as manifolds and exhaust pipes.
  4. Poppa
    Poppa Member
    OOOOPS.
    Most vapor lock
    occurs before the pumps on the suction side.
  5. Kirk
    If you have an in-tank fuel pump you need to replace it. If you add another pump in series with it, when the one in the tank quits completely your new pump won't help.
  6. C Nash
    You also need to check your voluum and pressure before replacing the pump. This could also be an electrical problem.
  7. Poppa
    Poppa Member
    As Chelse stated and I forgot, there is a connection just before the injector assembly for attaching a pressure gauge :blush: . A lot of auto supply houses will check it for you :laugh: . Again sounds like vapor lock but I am just an ole man. :(
