condensation questions
Discussion in 'Old RVUSA Forum' started by Old Forum Post, Dec 25, 2000.
  1. Old Forum Post
    Old Forum Post Senior Member
    [nlesniakowski@hotmail.com] Does anyone have any suggestions on how to keep water from forming in closets and cupboards in the colder weather? Any advice would be appreciated. Thanks Nancy
  2. Old Forum Post
    [bob t] open the doors, remember warm air rises, if trapped, will condensate, which is what you have. Open the doors & let the air circulate. Hope this helps
    bob t
  3. Old Forum Post
    [Gary B] Hi Nancy, you could get a dehumidifer and run that in your RV, I have a couple of them in my shop up here in MN during the summer, they remove a lot of water from the air. Good luck GB
  4. Old Forum Post
    [Brian] They are a couple easy ways to combat this problem. First the main question I have is do you live in it? The burning of propane creates moisture in the air. So the heavy users I can only suggest some Air dryer that can be found in most RV dealers. If this is purely a recreatinal vechicle then I would suggest Dri-z-air crystals. This should help if you have any further questions contact me at rvosparts@yahoo.com. I can help in anyway possible.
