Converter
Discussion in 'Class A / Diesel Pushers' started by ARFFMAN, May 3, 2012.
  1. ARFFMAN
    ARFFMAN Member
    I need to change out a faulty TODD PC 75 Power Source/ Charger. Can anyone comment/suggest a replacement converter/charger. I have a 1999 38 ft Kountry Aire. Is there a need of replacement of larger size? What feature should I look for?
  2. LEN
    LEN Senior Member
    I did a quick search on the below. Got results in the 225-400 range for a charger converter, but you might consider a cobination inverter as well. This will double the cost but you can go 12 to 120 120 to 12 and get the charger too.
    2000 watt power supply battery charger inverter
