Cruise control
Discussion in 'Talkback' started by weglidden, Jun 24, 2005.
  1. weglidden
    weglidden New Member
    Another problem?. My cruise control is working eratically, it will come on and engage, but then speeds the vehicle up and then kicks off when it reaches about 65mph. It is in a foretravel unihome with a catapillar deisel 3208...any thoughts?
  2. Kirk
    Cruise control
    What make is the speed control? It is probably an after market product.
  3. alcusmc
    alcusmc New Member
    Cruise control
    weglidden,
    If it is a King Control, it is possible that the ground is not making good contact or has become corroded. The control box is usually in the enginge compartment so it is not difficult to find.. Check the ground on it.
    alcusmc
  4. bmwbob
    bmwbob New Member
    Cruise control
    Another thought: It used to be that the cruise controls sensed speed from a coil looking at a magnet attached to the driveshaft.
    In later years, in most applications, they used a direct connection to the vehicle speed sensor line.
    It sounds as though that connection is not hooked up. The cruise control will power up, but is searching for a clue as to the speed of the vehicle. Finding no (or what appears as invalid) data, it failsafes by disengaging.
    Bob
