Re: dash air
Hello, I am not sure what the Evans Tempcon is. Do you change you temperature with a slide arm or is it digital? If slide arm, you may have a weak cable that is not keeping the AC control lever in the correct position. Have you tried going to HOT and see if the heat will gradually turn cool? I also had this problem with my AC and it was caused by the cable. The clamps that hold the cable into postion, two of them had broke. With these two clamps broke it caused a weak point in the cable. Replaced the clamps and all is well. The bad part, these clamps are under my dash and replacing them was not easy. -Steve
