Disconnect Switch?
fourcjtwo
Junior Member
Hi! I have a 2003 Tioga Class C. Do I have a disconnect switch? If so, where is it? I won't bore you with all the details of the headaches this is causing me, but THANKS to anyone who can answer this.
akjimny
Hi Fourcjtwo and welcome to the RVUSA Forum. I am assuming you mean a main battery disconnect. Most motorhomes I've seen have one near the door. Mine is a red key switch mounted in the footwell at the door. If this isn't what you are looking for, post back and we'll take another stab at it.:):)
vanole
Could be by the door as "akjimmy" said or it could be in the battery compartment could be a rotary switch or switch with an arm you throw one direction or the other.
Jeff
