dish net
Discussion in 'RV Tips & Tricks' started by icdcash, May 5, 2008.
  1. icdcash
    icdcash New Member
    We just bought our first motor home and I have a question about the satellite. We have dishnet at home and i would like to add a receiver DVR but I need to know if it will work all of my tv's in the motor home (5) Any suggestions would be appreciated.
  2. utmtman
    utmtman Senior Member
    Re: dish net
    Ok first off when you add the satellite dish you will need to tell the installers to connect it to all our televisions and second I believe you will need a box for each and every tv you are going to hook to. Unless you plan on using one box for all the tvs which would mean going to room where dvr was to change channels.
  3. Kirk
    Re: dish net
    Actually it just depends upon how your RV is wired for the TV and the dish use. If you use a portable dish on a tripod, you can use the existing coaxial cable to send the signal to your receiver if it does not use a signal splitter to cause your cable connection to be shared by two TVs. If the cable goes from the connection to a selector switch box, you need to install the dish receiver between the input and the selector switch.
    If your cable connection has no selector switch but supplies two TV sets that means that there is a signal splitter somewhere in the system. Those splitters will not pass the voltage that is sent to the dish LNB's via the coaxial cable so that would mean that you will have to run new cable. Of course, if you do it this way then both TV sets will have to watch the same satellite programing. For separate programing you would need to put in two receivers and they would each need their own coaxial cables and LNB's on the dish.
    For the RV, as long as you have the proper cabling, you can just take the receiver from the house and use it in the RV when traveling. There is no need to pay for an extra receiver.
  4. JamieB
    JamieB New Member
    Re: dish net
    icdcash.
    Are you wanting to watch different programming on all 5 tv's simultaneously, or do you want to have the watch the same channel on all 5 tv's at the same time? Does your motorhome have a dish on it already? If so, what kind?
  5. TexasClodhopper
    Re: dish net
    I'm suspicious of "one timers" that put a commercial website address in their profile.
    How many RVs have 5 TVs in them? Is this a record? Or is this normal?
    I guess I'm deprived, with only one TV.
