Draw-Tite and Reese
Discussion in 'RV Tips & Tricks' started by Dean, Nov 10, 2001.
  1. Dean
    Dean New Member
    I have a Draw-Tite weight distribution hitch and would like to add a Reese dual cam sway control. I have been told they are the same company. Do the two mentioned units match up OK?
    Thanks, Dean
  2. smoking1
    smoking1 New Member
    Draw-Tite and Reese
    Yes,The two will match up fine.
    Edited by - smoking1 on Dec 02 2001 12:03:08 AM
  3. grumps
    grumps New Member
    Draw-Tite and Reese
    Hi Dean, I thought about adding a dual cam setup to my reese hitch and was told you must have square spring bars. So if your spring bars are round that you must buy new bars as well as the hitch head.
  4. Dean
    Dean New Member
    Draw-Tite and Reese
    My Draw-Tite bars are round where they fit in receiver, but square on the chain end. Which end are you talking about?
    Dean
  5. Southstl
    Southstl New Member
    Draw-Tite and Reese
    I just purchased a new fifth wheel hitch from drawtite, and posted in the store is a letter from Reese/Drawtite. The letter stated that the only difference were the decals on the hitches.
    Steve
    '01 f250 CC PSD
    '00 Rockwood TT
    2 minature Dachshunds
    http:// www.texasboomers.org
  6. BarneyS
    BarneyS Senior Member
    Draw-Tite and Reese
    Dean, On another web site a poster had the same question. He e-mailed Draw-Tite and they said the add on Dual Cam system will work with the round Draw-Tite bars. On the flat ends of the bars, you bolt on the cam and the rest of the system is the same as the square bar type. You can see this setup at http://www.reesehitch.com/sway_control.html
    Hope this helps you out.
    Barney
    1997 Sunnybrook 26CKS TT
    1999 Dodge Ram 2500 quad cab, short bed, 5.9gas, auto. 3:54
    1996 Harley Davidson FLHRI
