Re: Dry rot problem
My problem is in between the window frame and closet as well as below the window frame almost to the bed frame. It is solid at the window frame, at the closet, and at the bed frame. About a 2 ft. square. I know I will have to take out the inside "wall", but was unsure what is between inside wall and outside wall, ie. "studs". Also unsure what to use on the new wood I put in, (paint, wallpaper, etc.)
Thanks, Larry
