I am looking for an RV to use for both summer and winter use. I am looking at older units, 78-88ish. A or C isn't an issue.
My question is, since I will be gone from the MH for a whole day leaving in the morning and comming back in the evening 12 hours later.
With a ducted furnaces fan using battery power how long will a battery typically last? Temps can be as low as single digit hi's so even just trying to keep the coach at a minimum temp will require the furnace to run a lot. I plan on insulating ceiling vents, outer walls under cabinets and some sort of window coverings to minimize heat loss to help out.
How long would a battery last if it was a typical 750 Ah deep cycle?
Will I have to fully charge the battery every morning and night or will it last 2 or 3 days?
Will the furnace work if battery power drops very low, ie almost dead? A non ducted furnace seems the simplest but they are only in pretty small Rv's and I would like something in the 22-27' range.Will a ducted furnace work for me at all or should I lok for non ducted units only?
Darrell
Darrell
