DUO THERM PARTS
Discussion in 'General RVing' started by MELVIN, Nov 8, 2005.
  1. MELVIN
    MELVIN New Member
    I HAVE A DUO-THERM FURNACE MODEL 25R. I NEED A FAN SWITCH FOR IT.
    IHAVE TRYED ABOUT EVERY THING I KNOW OF. THIS IS APPROXIMATELY
    1969 AND IS IN A SMALL SHASTA TRAILOR. I HAVE REBUILT THE
    FURNACE ALL EXCEPT THE THERMAL THAT TURNS THE FAN ON.
    THANK YOU
  2. sp
    sp Senior Member
    DUO THERM PARTS
    Melvin,
    Does your unit look like this? This one is out of a 76 prowler. I didn't need to replace the limit, fan or sail switches but I believe the one I circled is the fan switch. Are you having an issue with it's operation or do you just want to replace everything as you rebuild?
    sp
  3. sp
    sp Senior Member
    DUO THERM PARTS
    Melvin,
    sp
    ps:I can't seem to download the picture so let me know if you'd like me to email it to you.
  4. Kirk
    DUO THERM PARTS
    I wonder if you will ever find a new part for a furnace that old. What I would do is to remove the old one and then try and locate one that can be made to fit. You refer to it as a "thermal?" Does that mean that it is a thermostat type of fan switch? If so, you will need to know what temperature it should close. I don't have access to any manuals that go back that far.
  5. MELVIN
    MELVIN New Member
    DUO THERM PARTS
    STEVE P. AND KIRK.
    THANKS FOR THE REPLY. I CAN'T SEEM TO FIND THE PICTURE YOU
    SENT STEVE.YOU CAN E-MAIL ME IF YOU WOULD. KIRK, I HAVE BEEN
    TO MY LOCAL RV DEALER AND HE DOESN'T KNOW THAT TO CALL THE DISK
    OR WHAT THE VALUE IS.I THINK I AM IN MORE TROUBLE ANYWAY, IT
    HAS A GAS VALVE/THERMOSTAT AND PILOT ALL IN ONE UNIT AND I THINK
    THE THEERMOSTAT IS GOING BAD. ABOUT THE FAN SWITCH/THERMAL DISK,
    ALL I DOES IS TURN A SMALL BLOWER ON AT A CERTAIN DEGREES AND THEN
    OFF ON COOL DOWN. RIGHT NOW I PUT A 130 DEGREE WITH A 15 DEGREE
    COOL OFF.
    MY E-MAIL IS MAADETTY@CORLINK.COM
    THANKS AGAIN
