EPDM Roofing
Discussion in 'RV Tips & Tricks' started by jlovett, Jun 17, 2011.
  1. jlovett
    jlovett New Member
    I have a 2004 R Vision T.T. It has a rubber roof which I think is the original. Can I reseal the roof with a product such as Dicor's EPDM Sealant or does someone have another product they recommend. Don't want to do a complete roof overhaul! :cool:
  2. Triple E
    Triple E Senior Member
    Re: EPDM Roofing
    I am not sure of this but I have been told that Dicor is the producer of the rubber roof. Either way Dicor is the product you want to use. :approve:
    Ps; Welcome to RVUSA.
  3. C Nash
  4. jlovett
    jlovett New Member
    RE: EPDM Roofing
    THe roof is not leaking, just thought maybe a coat of the EPDM sealer might prolong the life of the original rubber roof.
  5. Grandview Trailer Sa
    Re: EPDM Roofing
    Your roof is only 7 or 8 years old. CLEAN it...do not put that coating on yet. When your roof is 15 years old, then coat it. EPDM roofs are designed to last 20 years...once you put that coating on, you will have to recoat it every year.
  6. Triple E
    Re: EPDM Roofing
    Ken my roof is 14 years old. Still looks great and I keep it clean. Should I reseal it next year or wait as long as I can?
  7. H2H1
    Re: EPDM Roofing
    Steve I would think as long as you keep it clean and not use any cleaner that remove the oil out of the rubber top you should be OK. But that just MHO. Mine is 8 years old and I keep it as clean as I can. I use spic and span on mine and so for I am happy with it.
  8. Triple E
    Re: EPDM Roofing
    10-4, I have been using your solution every since you told me about it. I think it works great. :approve:
    See hollis, some people do listen to you. :cool:
  9. C Nash
    Re: EPDM Roofing
    Steve that's what so good about this forum. All the rvers here have some great info. Never to old to learn, just forget!! :eek: :laugh:
  10. Triple E
    Re: EPDM Roofing
    What were we taking about Nash? :laugh: :laugh:
  11. C Nash
    Re: EPDM Roofing
    Done forgot :laugh:
  12. Grandview Trailer Sa
    Re: EPDM Roofing
    Steve, keep it clean as long as you can....that coating is designed to restore your roof when you actually start washing the white off and you begin to see the black rubber that is underneath. There are a lot of "not so honest dealers" that sell you the coating with a brand new trailer...and that is just plain BS.
  13. sophia james
    sophia james New Member
    RV Liquid Roof Coatings by epdmcoatings is the best choice you can try. For more details info you can check
    rvliquidroof.blogspot.
