Flat Towing
Discussion in 'Hitches & Towing Questions' started by filecutter, Mar 20, 2015.
  1. filecutter
    filecutter Junior Member
    Just had a fluid pump installed in our 2014 Dodge Caravan so we could flat tow and all went well with the Blue Ox hook-up but I'm concerned about the amount of power need to flat tow this vehicle. We were dolly towing a smaller car without much effect on the power. I'm wondering if the Dodge requires something other than placing in neutral, key in the accessory position and no brakes engaged.......Towing with the Chev Workhorse 8.1.........
  2. C Nash
    Welcome to the forum filecutter. I would want some kind of light in the MH to let me know the pump was working. Should be pretty simple to set it up. I would also want a braking system on the Caravan. Your tow limit is probably 5K and would guess you are near that.
