Furnace Thermostats
Discussion in 'Talkback' started by quadking, Apr 30, 2002.
  1. quadking
    quadking New Member
    I own a 30ft. Nomad 1995 Trailer and I have intermittent problems with the thermostat in the summer whille running the central air. I want to replace this one with an electronic type. Is this possible? or can I replace it with another standard type.
    Thank you in advance
  2. fjohn56
    fjohn56 New Member
    Furnace Thermostats
    I would think that you would be able to replace the thermostat with a digital one, depending on what kind you use. Also, have to be careful of voltage spikes and surges; as digital can't usually handle such things.(burnout) Also remember to place it away from the heating vents, to get a more accurate reading.
  3. rv wizard
    rv wizard New Member
    Furnace Thermostats
    A digital thermostat should be fine. Since it is controling 12 volts there should not be any problem with spikes unless you have a bad converter.
    Mike, Amy, Ashley, Candi
    2000 Gulf Stream Scenic Crusier on Spartan M.M. 330 hp. 6 spd. Allison
    #3 & #8 NASCAR
  4. fjohn56
    fjohn56 New Member
    Furnace Thermostats
    to all concerned;
    DUH!! on me....... I was thinking of A/C!Mr. quadking, rv wizard is correct. My mistake! :)
