Gas
Discussion in 'Class B Motorhomes' started by Norman Carlson, Apr 13, 2004.
  1. Norman Carlson
    Norman Carlson New Member
    1995 roadtrec 190 Engine stops at half tank. Goes again with more gas. Won;t show on computors Dodge
  2. hertig
    Gas
    How do you know it is at 'half tank'? Perhaps the guage is misalligned, or the sensor get stuck. 1) find out what size the tank is supposed to be.
    Then 2)Run it until it stops 3) Fill the tank 4) Compare the amount put in to the tank volume
    OR 2) run it until it stops 3)siphon/pump/drain the tank into a measured container 4) compare the amount removed after the engine stopped with the tank volume
    If the guage is accurate, then perhaps something is blocking the fuel line. Sort of like a straw which is only halfway into a drink can't get to the last half of the liquid.
